WCS Wireless Guest Access : Area, building restrictions don't work
Jan 28th, 2009
I use WCS to create guest accounts on a WLC4400 local database. Guest login works fine but i can login with any guest account on any campus, building, floor even if the account is apply only on one of those.
i use a custome Web auth page, this is the cisco's exemple page with our logo.
WLC44000 - 4.2.61.0
WCS - 4.262.11
WLAN Guest setup :
Layer 3 security : none
Web policy : authentication
Over-ride global - config enable
sschmidt Wed, 01/28/2009 - 15:34
So when you create the guest user you choose the specific campus/building/floor but the users are able to get access anywhere? How many controllers do you have?
elblanco_fr Thu, 01/29/2009 - 00:10
Yes exacly.
Only one controller with 15 "campus" (business unit).
AP are in HREAP (for corporate WLAN). of course (i know it's stupid) guest wlan is in a lwapp tunnel and wrong username or password don't works !
