ngp FIB filtering
roussillon
hi you all.
I have seen that there is a limit in FIB for severals cisco devices like NPE-G1, supervisor engine 1 , supervisor engine 2 and some supervisor engine 720 versions.
So i decided to filter BGP in order to reduce the tables size.
Let's say for our peering we have this config:
router bgp 30000
no synchronization
no bgp fast-external-fallover
bgp log-neighbor-changes
bgp dampening
network .......
neighbor Myneighbor remote-as 60000
neighbor Myneighbor send-community
neighbor Myneighbor soft-reconfiguration inbound
neighbor Myneighbor filter-list 1 out
no auto-summary
ip as-path access-list 1 permit ^$
if I change it to:
router bgp 30000
no synchronization
bgp dampening
network .......
no auto-summary
ip as-path access-list 1 permit ^60000_[0-9]*$
ip as-path access-list 1 deny any
1- will it reduce my routing table size while remaining complitly functional?.
2- do I need for this config that the neigtbor announce a default route?.
8 Replies 8
paolo bevilacqua
1. sorry what's the proposed change ?
2. default route is seldom needed in bgp peerings. Just use default static as needed, if you have multiple you can make them subject to track object statements.
the proposed change
instead of
Hi, seems like the change would allow more prefixes rather than less.
Hi .
Actually I get about 270000 routes.
that's why I was thinking about adding some filtering
hi paolo
why?
Because it also permits prefixes sourced by the AS in regexp rather that only ones originated by peer AS. Also, unless you do transit, you should not need no synchronization in bgp.
Hi.
So I think I have to get something else for doing bgp.  wath could substitute de 7204 taking in to account that I will add another bgp sesion?
I have catalyst 6500 doing all the switching stuff . If I upgrade the sup engines, say to 720 3BXL,  could I do BGP in the catalyst  and forget about 7200?
hanks
roussillon
Hy You all, Hy paolo.
I rectified my acces-list
router bgp 30000
no synchronization
bgp dampening
network .......
neighbor Myneighbor filter-list 2 in
no auto-summary
ip as-path access-list 2 permit ^60000_[0-9]*$
ip as-path access-list 2 deny any
will it be correct now?
thanks
