01-28-2009 04:22 AM - edited 03-06-2019 03:42 AM
hi,
I would like to know if is possible to configure 2 IP addresses on a single port of Cat3750.
I think that using the interface vlan xxx after I can use the ip address xxxx secondary command like on routers.
What do you say?
Thank you.
Regards.
Giuseppe
Solved! Go to Solution.
01-28-2009 04:25 AM
01-28-2009 04:36 AM
Yes you can do that on a SVI or a routed port , no different than a router .
01-28-2009 04:25 AM
You mean on a SVI?
Yes you can do that!
vlad
01-28-2009 04:36 AM
