Nessus uploading issue with NAC
Jan 28th, 2009
Dear All,
I have downloaded Nessus plugins (2 series) and rename the file as cisco says but when I upload it CAM says incompatible file type.
Any idea?
nomair_83 Thu, 01/29/2009 - 00:47
Size is 90.5 MB and I have renamed it as "plugins.tar.gz" but when I upload, CAM says incomptible file type.
sampathsundararajan Thu, 01/29/2009 - 06:20
It's the problem with the size of the file. It can't accept 90 MB as it is. Split that file and make sure the single file is around 16MB to 20 MB. It will definitely work.
Try and let me know.
Sam
nomair_83 Thu, 01/29/2009 - 06:24
Ok Im spliting it right now , I thought that it should be uploaded as it is except for renaming the file.:)
just give me 10 mins
nomair_83 Thu, 01/29/2009 - 06:36
when I upload single file of plugins it works but if I made a folder of 8 files sized 56 kb and zip it with
plugins.tar.gz as file name it shows same error "Result: Incompatible file types "
Strange:)
sampathsundararajan Thu, 01/29/2009 - 06:43
In this scenario, you have to go with single file only. You need to split the files as I said earlier and upload it individiually. This is how it works. And it works well.
Let me know.
Sam
nomair_83 Thu, 01/29/2009 - 06:46
this option is not feasible dear , it will take ages:) to upload sinlge file...
sampathsundararajan Thu, 01/29/2009 - 06:49
It does not take much time for 16 MB. It's the only option available, if you need to use the nessus plug-in functionality.
Sam
nomair_83 Thu, 01/29/2009 - 07:07
If I dont use nesssus then how NAC will scan the Client pc?
sampathsundararajan Thu, 01/29/2009 - 07:11
See, you are using nessus plugin in order to perform the vulnerability assessment on the client machines. If it detects a vulnerability on the client machines, it will automatically put them in the quarantine vlan.
If you want to use the nessus option, upload the plugins as I told earlier. You can upload it after splitting it. It works golden.
Sam
nomair_83 Thu, 01/29/2009 - 09:12
Ok Sam,
Im facing one more problem , when I add WLAN in WLC for NAC it gives me error that can not creat WLAN make sure that qurantine vlan is not 0 ...
I have set Qurantine vlan as X but still its not adding the WLAN when I enable NAC on that interface.
sampathsundararajan Thu, 01/29/2009 - 09:41
When you add WLAN on WLC, do not configure anything as the quarantine VLAN.
Try adding the WLAN on WLC without mentioning the quarantine vlan and let me know.
nomair_83 Thu, 01/29/2009 - 10:17
So u mean to say after adding WLAN then I configure Qurantine vlan and enable NAC on WLAN ?
sampathsundararajan Thu, 01/29/2009 - 10:31
Create a virtual interface and assign that interface to the wlan that you create. Configure the snmp and it should be golden.
Let me know the result.
