OSPF configuration
Jan 28th, 2009
I have two routers connected by a serial cable. I have configured ospf but it's not working.
this is how I did it/;
conf t
router ospf
network 192.1.1.0 0.0.0.255 area 0
and on the other router exactly the same but different network number but the same area, my problem here is I cannot see the networks that i am advertising on the on the router and vice versa.
please help what could be a problem here?
Joseph W. Doherty Wed, 01/28/2009 - 06:12
The two routers need to share a link with OSPF. You write you're using a "different network number" on the other router. If you want to see other routes, those interfaces need to be known to OSPF.
Assuming the shared link is 192.1.1.0/24 and the first router has another interface such as 192.1.2.0/24 and the second router 192.1.3.0/24, config might look like:
first router:
router ospf
network 192.1.2.0 0.0.0.255 area 0
second router:
router ospf
network 192.1.3.0 0.0.0.255 area 0
mailaglady2 Wed, 01/28/2009 - 06:40
I have tried that but I still cant see these routes on my routing table.. when I do my "sh ip route" I can't see these routes. i can only see the directly connected ones.
netwalkr1 Wed, 01/28/2009 - 09:05
If both serial interfaces are configure in a point-to-point (PPP/HDLC) configuration make sure you have IP connectivity. I know this is basic but, without the configs posted I'm assuming worst case scenario. Once you verified connectivity, use the network statements 192.1.1.0 0.0.0.255 area 0 if that is the IP subnet of the serial interfaces. You may also want to configure loopback interfaces for the neighbor ID.
See this link for a step-by-step walkthrough.
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080094057.shtml
HTH,
Shaun
zartar911 Wed, 01/28/2009 - 09:35
As what Shaun said, first make sure your layer 2 (port & line are up) & 3 (Ping the other IP address) are working.
After verifying that a sample OSPF configuration could be as follows:
ROUTER1
router ospf 1
network 165.148.120.0 0.0.0.252 area 0
ROUTER2
router ospf 1
One other thing to check is the ospf network types are the same.
Tim
mailaglady2 Thu, 01/29/2009 - 00:56
Thanks it worked, my problem was with the serial.
I had configured like this 165.148.120.0 0.0.0.0 area 0 instead of
165.148.120.0 0.0.0.3 area 0.
Thanks good people, you have been a great help.
netwalkr1 Thu, 01/29/2009 - 05:49
Your welcome! Please mark this thread as "solved" and don't forget to rate the responses.
