01-28-2009 06:27 AM - edited 03-04-2019 01:00 AM
I have two remote offices that connect back to me through two P2P T1 lines (for a total of 3Mb). Currently the load balancing is done through ip load-sharing per-packet but we are looking into video conferencing so I can't use that anymore.
I want to configure multilink interfaces and bundle the serial ports and I have a question about the config on the hub router. I have configured a multilink interface before but I have never done two on the same router. Would this be the correct config?
conf t
interface multilink1
ip address x.x.x.x y.y.y.y
encapsulation ppp
ppp multilink
ppp multilink group 1
interface serial0/0/0:0
encapsulation ppp
ppp multilink
interface serial0/0/1:0
encapsulation ppp
ppp multilink
interface multilink2
encapsulation ppp
ppp multilink
ppp multilink group 2
interface serial0/1/0:0
encapsulation ppp
ppp multilink
interface serial0/1/1:0
encapsulation ppp
ppp multilink
Solved! Go to Solution.
01-28-2009 06:59 AM
The interface number is what your referencing the serial interface to. Mutlilink 1 or Mutlilink 2
Does my explanation make sense?
**Update: Sorry, I just double-checked and you do need it. Sorry for the mess up. Your config looks just fine.
01-28-2009 06:47 AM
Under the multilink interface you don't need ppp multilink group 1, but other than that, it looks good.
Hope that helps.
01-28-2009 06:52 AM
Can you clarify that a bit? I thought the purpose of the 'ppp multilink group 1' statement was to define which multilink interface the multilink to which the group was tied. If I don't have that statement on those interfaces then why would I need it on the serial interfaces?
01-28-2009 06:59 AM
01-28-2009 07:01 AM
I believe you will need multilink group x to associate with each link
