QOS - Policing 6509
Jan 28th, 2009
I have been doing policing on a 6509 to limit the bandwidth from one host to another (Netapp Snapmirror traffic). When using the following police config it produced a steady 8.5 mb stream.
police cir 8500000 bc 265625 be 265625 conform-action transmit exceed-action drop violate-action drop
We have more bandwidth available and we want to bring it up to 18mb limit. Is there an optimal be / bc setting to produce the constant stream? When I bring the command up to police cir 18000000 we are seeing inconsistent stream
Joseph W. Doherty Wed, 01/28/2009 - 10:59
Could you further explain what's an "inconsistent stream"? I.e., what's the problem you think you're seeing.
gizbri Wed, 01/28/2009 - 11:05
Thanks for the response. With the original police command , it streamed at a constant 8.5 mb. When I raised the speed up to 18mb we see the stream of traffic bounce between 8 and 18 mb. It was my though that is was doing more re-transmissions at the higher rate therefore, the fluctuation.
Joseph W. Doherty Wed, 01/28/2009 - 11:18
That might just be the nature of the traffic and especially how it interacts with the policer.
If you want to confirm the policer is working correctly, you would need to use a traffic generator where you can control the rate being sent.
