Upgrading Presence
Jan 28th, 2009
I am trying to upgrade my Presence server from 6.0.4 to 6.0.5 at the minute. When i download the 2 files i Try to join them to make one file using the following command. It fails to work
COPY /B UCSInstall_UCOS_6.0.5.1000-13.sgn.iso_part1of2+UCSInstall_UCOS_6.0.5.1000-13.sgn.iso_part2of2 UCSInstall_UCOS_6.0.5.1000-13.sgn.iso
Has anyone come across this before. Am I doing something wrong?
Jaime Valencia Wed, 01/28/2009 - 12:31
  • Cisco Employee,
  • Hall of Fame,
    2011
format looks fine
COPY /B File1+File2 Dstfile
might want to check the checksum of the files, maybe they're corrupted
try in another PC, maybe the issue is the PC
java
if this helps, please rate
