871w wireless configuration
Jan 28th, 2009
I know this question was asked many times, but I'm still not able to finalize my configuration on 871w. LAN part works fine, but wireless clients do not get DHCP IP. here is the config:
Building configuration...
Current configuration : 2092 bytes
version 12.4
no service pad
hostname WROUTER
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 4096
no aaa new-model
dot11 syslog
dot11 ssid sputnik
vlan 1
authentication open
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.254
ip dhcp pool vlan1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
dns-server 167.206.245.7 167.206.245.71
lease 10
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
interface Dot11Radio0
no ip address
encryption vlan 1 mode wep mandatory
encryption key 1 size 128bit 0 0D9E3A3AF78EA7A156A6D6FB09 transmit-key
ssid sputnik
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
station-role root
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 dhcp
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
I'dliket o have LAN and WLAN clients in same 192.168.1.0 subnet.
Thanks.
Stephen Rodriguez Wed, 01/28/2009 - 08:22
  • Purple, 4500 points or more
try removing the VLAN statement under the SSID, and the encryption lines. Just place the main Dot11Radio0 Interface in Bridge-group 1 and see how that works for you. SO:
dot11 ssid sputnik
authentication open
no interface dot0.1
int dot0
bridge-group 1
HTH,
Steve
bamnocadmin Wed, 01/28/2009 - 10:21
thank you.
I read this forum and i found that I need vlan 1 for each encryption line. Here is the config that works for me:
Current configuration : 2130 bytes
version 12.4
no service pad
hostname xxxxx
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
dot11 ssid sputnik
vlan 1
authentication open
guest-mode
ip source-route
ip dhcp pool vlan1
lease 10
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
bridge irb
ip address dhcp
ip nat outside
duplex auto
speed auto
no cdp enable
no ip address
encryption vlan 1 key 1 size 128bit 0 0D9E3A3AF78EA7A156A6D6FB09 transmit-key
ssid sputnik
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
no cdp enable
bridge-group 1
interface Vlan1
no ip address
ip nat inside
bridge-group 1
interface BVI1
ip nat inside
ip http server
control-plane
bridge 1 route ip
line con 0
password cisco
login
no modem enable
line aux 0
line vty 0 4
password cisco
login
end
ramosm1974 Mon, 10/29/2012 - 13:13
This is what I got and it has been working for me. From my modem to my RV016 to my 871w.  Once I figure out the PPPOE the 871w will be my only router running, and figure out the port forwarding, but most important I need to configure PPPOE.
mr-r1#sh star
Using 3825 out of 131072 bytes
! Last configuration change at 08:10:30 PCTime Sun Oct 28 2012 by ramosm
! NVRAM config last updated at 08:10:33 PCTime Sun Oct 28 2012 by ramosm
version 12.4
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname mr-r1
boot-start-marker
boot-end-marker
logging buffered 64000
logging rate-limit 20
enable secret 5 $1$PDK9$YSz8GsnVsDYevR1hVGMG70
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone PCTime -8
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-3978252741
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3978252741
revocation-check none
rsakeypair TP-self-signed-3978252741
crypto pki certificate chain TP-self-signed-3978252741
certificate self-signed 01 nvram:IOS-Self-Sig#B.cer
dot11 syslog
dot11 ssid ramfam
vlan 55
authentication open
mbssid guest-mode
ip source-route
ip dhcp excluded-address 10.25.55.1 10.25.55.49
ip dhcp excluded-address 10.25.55.76 10.25.55.254
ip dhcp excluded-address 10.25.50.1 10.25.50.49
ip dhcp excluded-address 10.25.50.76 10.25.50.254
ip dhcp pool Data
   import all
   network 10.25.50.0 255.255.255.0
   dns-server 10.55.55.1 4.2.2.1
   domain-name MR-Lab1
   default-router 10.25.50.1
   lease 25
ip dhcp pool Wireless
   import all
   network 10.25.55.0 255.255.255.0
   default-router 10.25.55.1
   dns-server 10.55.55.1 4.2.2.2
   lease 25
ip cef
ip domain name MR-Lab1.com
ip name-server 10.55.55.1
username ramosm privilege 15 secret 5 $1$J2cq$abQJlRlZgmIlEDPX/jd8A1
archive
log config
  hidekeys
no ip ftp passive
bridge irb
description AirNet 1100
speed 100
spanning-tree portfast
description Extra cat5
description Ubuntu PC
description PS3
speed 100
description Internet Wan Port
ip address 10.55.55.105 255.255.255.0
ip nat outside
speed 100
full-duplex
no ip address
encryption vlan 55 key 1 size 128bit 0 AB2081CA12B126DD2F95ABCF32 transmit-key
encryption vlan 55 mode wep mandatory
broadcast-key vlan 55 change 30
ssid ramfam
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0
station-role root
interface Dot11Radio0.55
encapsulation dot1Q 55 native
bridge-group 1
interface Vlan1
ip address 10.25.50.1 255.255.255.0
ip nat inside
interface Vlan55
no ip address
bridge-group 1
interface BVI1
ip address 10.25.55.1 255.255.255.0
ip nat inside
ip route 0.0.0.0 0.0.0.0 10.55.55.1
ip http server
ip http authentication local
ip nat inside source list 2 interface FastEthernet4 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.25.50.0 0.0.0.255
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 10.25.55.0 0.0.0.255
control-plane
bridge 1 route ip
line con 0
exec-timeout 30 0
password Cisco
logging synchronous
no modem enable
line aux 0
line vty 0 4
exec-timeout 20 0
password Cisco
logging synchronous
end
mr-r1#
