01-28-2009 07:29 AM - edited 03-11-2019 07:43 AM
Dear all,
how to block teamviewer remote desktop on cisco ASA5550.
prompt response is much appicate.
thanks & regards
01-29-2009 07:22 AM
Since teamviewer seems to use outbound port 80 (http) for the communication channel, effectively blocking it will be somewhat complex. The best way I can think to accomplish this would be to define custom regex to match the identified traffic and then use a class-map to block it.
This Cisco article describes the process:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080940e04.shtml
Hope this helps.
02-01-2009 09:13 PM
Could you please try the following conf.in your ASA to block teamviewer .
http-map inbound_http
port-misuse p2p action drop log
port-misuse tunneling action drop log
class-map http-port
match port tcp eq www
policy-map inbound_policy
class http-port
inspect http inbound_http
service-policy inbound_policy interface inside
Hope this helps
02-02-2009 12:04 AM
many thanks for all your efforts,
i will try and show the result, meanwhile, some other software similiar to teamview, like logmeon, securelogin, Timbuktu Pro, can also protect from the above statements.
thanks in advance,
02-03-2009 09:13 PM
Could you block team viewer with that conf. Otherwise we can try some other way
Jithesh
