CME or CMBE
Jan 28th, 2009
I have a client that is looking at both technologies. I can not find a document that does a side by side comparison of features between the two. Even the SRND doesn't show what features like mobility, paging, etcd.are offered. Any advice on feature comparisions between the two running version 7.
paolo bevilacqua Wed, 01/28/2009 - 08:55
  • Hall of Fame,
    Founding Member
How many extensions do they require? Also check on CMBE price before thinking is less that CM+appliance and comparable to CME.
Also the administration of the products is totally different some may not like give cli comamnds most of the time or viceversa a eb interface.
ray.mullen Wed, 01/28/2009 - 09:15
The client has about 50 phones. I am looking for mostly what features that CME has compared to CMBE like paging is better with CME, but the mobility features may be more robust with CMBE etc.
paolo bevilacqua Wed, 01/28/2009 - 10:07
  • Hall of Fame,
    Founding Member
If you do the math you will find that budget wise it can be difficult to justify CMBE cost for just 50 phones. In that segment, CME wins "hands down".
Certainly there are features that are in one but not in the other '(e.g. cm 7.0 have monitoring and recording, while CME has line-selection for CFA), but I think are more the fundamental differences influencing the choice.
Jaime Valencia Wed, 01/28/2009 - 10:16
  • Cisco Employee,
  • Hall of Fame,
    2011
there is no quick and easy table for what you want, only separate documents:
Cisco Unified Communications Manager Version 7.0
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/data_sheet_c78-485333.html
Cisco Unified Communications Manager Express 7.0
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps4625/data_sheet__c78-484777.html
Cisco Unified Communications Manager Business Edition
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps7273/product_data_sheet0900aecd805e6985.html
Release Notes for Cisco Unified Communications Manager Release 7.0(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/rel_notes/7_0_1/cucmbe-rel_notes-701.html
also for extra considerations read the CUCMBE section of SRND
java
if this helps, please rate
