Sticky Port Security 3560
Answered Question
Jan 28th, 2009
Is there a better solution to resetting sticky port security on a single port on a Catalyst 3560 SW when a PC is swapped out than:-
sw(config-if)#no switchport port-security mac-address sticky
sw(config-if)#switchport port-security mac-address sticky
sw(config-if)#shutdown
sw(config-if)#no shutdown
sw#wr
I know that you can clear the whole mac address table at the enable prompt, but that is a security risk until all the ports have re-learned the mac addresses.
Correct Answer by Mark Yeates about 8 years 5 months ago
I think you are looking for the "clear port security sticky interface fa0/X" command. Instead of turning off port security and the interface and enabling them this command will do the same thing. I don't see a security issue by doing this.
http://www.ciscosystems.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_40_se/command/reference/cli1.html#wpmkr4260639
HTH,
Mark
Overall Rating: 5 (1 ratings)
Correct Answer
Mark Yeates Wed, 01/28/2009 - 07:56
  • Gold, 750 points or more
HTH,
Mark
paultjohnson Wed, 01/28/2009 - 08:26
Many thanks Mark, hadn't followed the sub-commands far enough!
