error-disable on Catalyst 2960 ethernet port
Jan 28th, 2009
I have a catalyst 2960 switch installed. The port is in error-disable state. It was working fine a few days ago. I have checked the punch down wiring and the physical cables and they are fine. If I connect it to a different port on the switch it works fine.
Here is the configuration for that port:
interface FastEthernet0/17
switchport mode access
switchport voice vlan 100
macro description cisco-phone-data
spanning-tree portfast
here is the port it is connected to:
interface FastEthernet0/18
As you can see they are identical.
Here is the show int on the port:
FastEthernet0/17 is down, line protocol is down (err-disabled)
Hardware is Fast Ethernet, address is 0024.134c.6311 (bia 0024.134c.6311)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 1d02h, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5510740 packets input, 369993922 bytes, 0 no buffer
Received 682 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
140716940 packets output, 40486108345 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
I am debating if it is a hardware issue. I also have tried no shutdown on the port to re-enable it and that did not work.
Any ideas?
t4tauseef33 Wed, 01/28/2009 - 08:41
you have to shutdown the interface and then have to apply the no shut command.
Mark Yeates Wed, 01/28/2009 - 08:48
Can you please post the logs of the switch? This will usually show the reason for the interface going into err-disable.
gandhikunal Fri, 01/30/2009 - 17:33
can u please post o/p of  command 'sh interfaces status err-disabled' even this command show the reason of err-disable
