Signal Strength Decrease when adding second SSID
Jan 28th, 2009
I am having an issue with an 1130AG Access point. When I add a second (Guest) SSID to the access point it seems to greatly decrease the signal strength. It gets to the point where the wireless is unusable even 30 feet from the AP. Both SSID's are working correctly in that I can access the proper VLAN but I am hoping that there is a configuration issue that is causing the signal strength decrease. Has anybody seen these type of results when adding a VLAN and SSID to a 1130AG access point? If needed I can upload the configuration.
Thanks I would greatly appreciate any help with this issue as I am having great difficulties.
jeff.kish Wed, 01/28/2009 - 11:38
Well, I've never seen this before, but I can at least confirm that it should not happen :) As you say, maybe if you upload your config then someone can review it and ensure it is properly configured.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
