What do cisco marco's do
Jan 28th, 2009
I have read cisco's doc on what macro's do and am still unclear..
I found this configuration in a switch that we are taking over
I dont see the word macro in the config in any other place but this interface
interface GigabitEthernet0/17
switchport trunk allowed vlan 14,17
switchport mode trunk
macro description cisco-switch | cisco-switch | cisco-switch
auto qos voip trust
spanning-tree link-type point-to-point
nyc-swi#show parser macro name cisco-switch
Macro name : cisco-switch
Macro type : default interface
# macro keywords $native_vlan
# Access Uplink to Distribution
# Do not apply to EtherChannel/Port Group
# Define unique Native VLAN on trunk ports
# Recommended value for native vlan should not be 1
switchport trunk native vlan $native_vlan
# Update the allowed VLAN range such that it
# includes data, voice and native VLANs
switchport trunk allowed vlan ALL
# Hardcode trunk
# Configure qos to trust this interface
auto qos voip trust
# 802.1w defines the link as pt-pt for rapid convergence
Paolo Bevilacqua Wed, 01/28/2009 - 09:53
  • Hall of Fame,
    Founding Member
The hardcoded macro doesn't show in configuration but you have correctly visualized its definitions.
Then it's up to you to decide if these are appropriate for your application.
brooklynheight Wed, 01/28/2009 - 11:14
Ok..so basically i could make
a macro that for examples
makes all interfaces 100 full duplex
set for vlan 5
and portfast?
than just apply this macro to the interfaces
that i want to have the configuration?
and as you said...cisco ships with
default macros?
Paolo Bevilacqua Wed, 01/28/2009 - 12:47
  • Hall of Fame,
    Founding Member
Yes. Try show parser macro to see them all.
