ANY-Connect Client - Disable Group-Authen. drop-down selection
Jan 28th, 2009
I would like to disable the ANY-Connect Client "Group-Authentication" Drop-Down Field. User should enter the Groupname manually.
Ivan Martinon Mon, 02/02/2009 - 17:41
This feature is not available, you either have to chose between group alias (pulldown menu) or Group URL where the user puts the groupname on the link when reaching the ASA webportal.
