Change http password
Answered Question
Jan 28th, 2009
I have the telnet and enable password for my C2950 switch, but I can't access it through http with the admin username. How can I change the http password used for that protocol by logging on the switch through telnet ?
Correct Answer by Roberto Salazar about 8 years 3 weeks ago
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea9/release/notes/OL11484.html
The HTTP server interface must be enabled to display the device manager. By default, the HTTP server is enabled on the switch. Use the show running-config privileged EXEC command to see if the HTTP server is enabled or disabled.
Configure the HTTP server interface for the type of authentication that you want to use.
•enable-Enable password, the default method of HTTP server user authentication.
•local-Local user database, as defined on the Cisco router or access server.
•tacacs-TACACS server.
Overall Rating: 5 (1 ratings)
Correct Answer
Roberto Salazar Wed, 01/28/2009 - 11:22
