Clocking Issue with 2 E-1's - One interface is up/up other is up/down
Jan 28th, 2009
Here is my config:
card type e1 0 0
card type e1 0 1
card type e1 0 3
network-clock-participate wic 0
no network-clock-participate wic 1
network-clock-participate wic 3
network-clock-select 1 E1 0/3/0
controller E1 0/0/0
framing NO-CRC4
channel-group 0 timeslots 1-31
controller E1 0/1/0
framing NO-CRC4
controller E1 0/3/0
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-20 type r2-digital r2-compelled ani
cas-custom 1
country telmex use-defaults
category 2
answer-signal group-b 1
interface Serial0/0/0:0
description Telmex D32-0811-0825
ip address 201.XX.XX.129 255.255.255.252
ip access-group Serial0/0/0:0_in in
ip nbar protocol-discovery
ip flow ingress
load-interval 30
no fair-queue
interface Serial0/1/0:0
description Telmex D32-0811-0826
ip address 201.XX.XX.133 255.255.255.252
ip flow ingress
load-interval 30
no fair-queue
ip route 0.0.0.0 0.0.0.0 Serial0/0/0:0
ip route 0.0.0.0 0.0.0.0 Serial0/1/0:0
CSCR001#sh ip int b
Serial0/0/0:0 201.XX.XX.129 YES NVRAM up up
Serial0/1/0:0 201.XX.XX.133 YES NVRAM up down
I am lost at this point and cannot understand why I cannot get this other interface up.
CSCR001#sh controllers e1 0/0/0:0 brief
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
Cablelength is Unknown
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20071011, FPGA: 13, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CSCR001#sh controllers e1 0/1/0:0 brief
E1 0/1/0 is up.
No alarms detected.
CSCR001#sh controllers e1 0/3/0:0 brief
E1 0/3/0 is up.
No alarms detected.
Richard Burts Wed, 01/28/2009 - 12:20
Rick
The obvious difference between the one that works and the one that does not work is this:
do you know why network-clock-participate is turned off on wic 1?
Rick
Rick Morris Wed, 01/28/2009 - 12:23
I had wondered this too.
We had a lot of slips on the E-1's and the voice trunks. This was something we worked out with TAC and they told us to do this.
I am not 100% sure why but this was something I wondered I should check.
At this time I do not have out-of-band access so I cannot make changes on the fly just yet. I will gain access via out-of-band later this week but wanted to check and see if anyone else had any ideas.
Rick
Paolo Bevilacqua Wed, 01/28/2009 - 12:42
likely you will find that interface down is due to a problem with the circuit.
network-clock-participate or lack of it will not influence interface status, and since all circuits appears to be coming from a same provider, all clocks are equivalent.
