IP phones can't register on CME
Jan 28th, 2009
I have CME version 4.1 on IOS 12.4(15)T8 & 7941 & 7911 ip phones.
I have 64 MB flash & 256 DRAM.
IP phones can't register & i got the following error:
CME error writing config file XMLDefault7961GE-1.cnf.xml -1/1151
CME error writing config file XMLDefault7961GE-2.cnf.xml -1/1224
CME error writing config file XMLDefault7941.cnf.xml -1/1059
CME error writing config file XMLDefault7941GE.cnf.xml -1/1059
CME error writing config file XMLDefault7931.cnf.xml -1/1047
CME error writing config file XMLDefault7911.cnf.xml -1/1047
CME error writing config file XMLDefault7906.cnf.xml -1/1047
CME error writing config file XMLDefault7985.cnf.xml -1/1047
CME error writing config file XMLDefault7912.cnf.xml -1/834
CME error writing config file XMLDefault7910.cnf.xml -1/515
CME error writing config file XMLDefault7935.cnf.xml -1/414
CME error writing config file XMLDefault7960.cnf.xml -1/929
CME error writing config file XMLDefault-1.cnf.xml -1/1033
CME error writing config file XMLDefault-2.cnf.xml -1/1106
ITS error writing config file XMLDefaultCIPC.c
Jan 28 18:49:53.115: Can't open file flash:/XMLDefault7961GE-1.cnf.xml
Jan 28 18:49:53.119: Can't open file flash:/XMLDefault7961GE-2.cnf.xml
Jan 28 18:49:53.119: Can't open file flash:/XMLDefault7941.cnf.xml
Jan 28 18:49:53.119: Can't open file flash:/XMLDefault7941GE.cnf.xml
Jan 28 18:49:53.123: Can't open file flash:/XMLDefault7941GE.cnf.xml
Jan 28 18:49:53.123: Can't open file flash:/XMLDefault7931.cnf.xml
Jan 28 18:49:53.123: Can't open file flash:/XMLDefault7911.cnf.xml
Jan 28 18:49:53.123: Can't open file flash:/XMLDefault7906.cnf.xml
Jan 28 18:49:53.127: Can't open file flash:/XMLDefault7906.cnf.xml
Jan 28 18:49:53.127: Can't open file flash:/XMLDefault7985.cnf.xml
Jan 28 18:49:53.127: Can't open file flash:/XMLDefault7912.cnf.xml
Jan 28 18:49:53.127: Can't open file flash:/XMLDefault7910.cnf.xml
Jan 28 18:49:53.131: Can't open file flash:/XMLDefault7910.cnf.xml
Jan 28 18:49:53.131: Can't open file flash:/XMLDefault7935.cnf.xml
Jan 28 18:49:53.131: Can't open file flash:/XMLDefault7960.cnf.xml
Jan 28 18:49:53.131: Can't open file flash:/XMLDefault-1.cnf.xml
Jan 28 18:49:53.135: Can't open file flash:/XMLDefault-1.cnf.xml
Jan 28 18:49:53.135: Can't open file flash:/XMLDefault-2.cnf.xml
Jan 28 18:49:53.135: Can't open file flash:/XMLDefaultCIPC.cnf.xml
Jan 28 18:49:53.135: Can't open file flash:/XMLDefaultCIPC.cnf.xmlnf.xml -1/1011
Any ideas????
youssef.ahmed Wed, 01/28/2009 - 21:07
outer(config-telephony)#do sh run
Building configuration...
Current configuration : 3723 bytes
! No configuration change since last restart
version 12.4
hostname Router
boot-start-marker
boot system flash c2800nm-ipvoicek9-mz.124-15.T8.bin
boot-end-marker
no aaa new-model
clock timezone EG 2
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp pool voice
network 192.168.200.0 255.255.255.0
option 150 ip 192.168.100.230
default-router 192.168.200.221
domain-name wr
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
archive
log config
hidekeys
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 192.168.200.230 255.255.255.0
ip helper-address 192.168.100.230
interface FastEthernet0/0.3
encapsulation dot1Q 3
ip address 192.168.100.230 255.255.255.0
interface Service-Engine0/0
ip unnumbered FastEthernet0/0.3
service-module ip address 192.168.100.231 255.255.255.0
service-module ip default-gateway 192.168.100.230
interface FastEthernet0/1
ip address 10.11.12.1 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
ip route 192.168.100.231 255.255.255.255 Service-Engine0/0
ip http server
no ip http secure-server
tftp-server flash:apps41.8-3-2-27.sbn
tftp-server flash:cnu41.8-3-2-27.sbn
tftp-server flash:cvm41sccp.8-3-2-27.sbn
tftp-server flash:dsp41.8-3-2-27.sbn
tftp-server flash:jar41sccp.8-3-2-27.sbn
tftp-server flash:SCCP41.8-3-3S.loads
tftp-server flash:term41.default.loads
tftp-server flash:apps41.8-2-2ES1.sbn
tftp-server flash:cnu41.8-2-2ES1.sbn
tftp-server flash:cvm41sccp.8-2-2ES1.sbn
tftp-server flash:dsp41.8-2-2ES1.sbn
tftp-server flash:jar41sccp.8-2-2ES1.sbn
tftp-server flash:SCCP41.8-2-2SR1S.loads
tftp-server flash:P00308000400.bin
tftp-server flash:P00308000400.loads
tftp-server flash:P00308000400.sb2
tftp-server flash:P00308000400.sbn
control-plane
voice-port 0/2/0
voice-port 0/2/1
sccp ccm 192.168.100.200 identifier 1
sccp ccm group 123
associate ccm 1 priority 1
associate profile 1 register mtp001bd4706a18
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 5
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 6
associate application SCCP
shutdown
telephony-service
load 7941GE P00308000400.sbn
load 7941 P00308000400
max-ephones 3
max-dn 3
ip source-address 192.168.100.230 port 2000
auto assign 1 to 3
cnf-file location flash:
voicemail 3030
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Jan 29 2009 07:59:33
ephone-dn 1 dual-line
number 4000
call-forward busy 3030
call-forward noan 3030 timeout 18
ephone-dn 2 dual-line
number 4001
ephone-dn 3 dual-line
number 4002
ephone 1
no multicast-moh
mac-address 001B.D4A0.7B65
type 7941GE
button 1:1
ephone 2
no multicast-moh
mac-address 001B.0C96.5FAF
type 7911
ephone 3
no multicast-moh
line con 0
line aux 0
line 194
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
login
scheduler allocate 20000 1000
ntp master
end
Router(config-telephony)#
Erick Bergquist Wed, 01/28/2009 - 23:59
  • Silver, 250 points or more
Try removing the command "cnf-file location flash:" under telephony-service. The default is store the config files in memory.
Do you have enough space free on the router flash, and is it inserted in the router all the way? Can you save the running config to the flash (see if new files can be saved, etc on the flash). Is there a write-protect switch on the flash you are using maybe?
youssef.ahmed Thu, 01/29/2009 - 03:18
I did the following:
1-erase flash
2-Uploaded flash:c2800nm-adventerprisek9-mz.124-11.XJ4.bin on the flash.
3-Uploaded CME files related to IOS.
4-Put alternate TFTP server,the same ip address of primary ip address,as work around,then save.
reloaded ip phones.
Finally the problem solved by the previous conf.
Thanks for your replies :)
Rrgards,
Ahmed Kamal
Nicholas Matthews Thu, 01/29/2009 - 06:10
  • Red, 2250 points or more
Hi Ahmed,
As suspected, it sounds like you have some flash problems. I would take some time and see if you're having problems and possibly reformat the compact flash.
hth,
nick
