Trying to configure NM-32a on 2811
Answered Question
Jan 28th, 2009
I'm having a tough time configuring my Cisco 2811 Access Server. This router has the NM-32A card.
This is what I have done so far. I plugged the octal cable into bottom left port marked 8-15. I plugged cable # 2 into a switch that is turned on.
This is the output I am getting so far.
Tty Line Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 0 0 CTY - - - - - 0 0 0/0 -
I 1 1 AUX 9600/9600 - - - - - 0 0 0/0 -
1/0 66 TTY 9600/9600 - - - - - 0 0 0/0 -
1/1 67 TTY 9600/9600 - - - - - 0 0 0/0 -
1/2 68 TTY 9600/9600 - - - - - 0 0 0/0 -
1/3 69 TTY 9600/9600 - - - - - 0 0 0/0 -
1/4 70 TTY 9600/9600 - - - - - 0 0 0/0 -
1/5 71 TTY 9600/9600 - - - - - 0 0 0/0 -
1/6 72 TTY 9600/9600 - - - - - 0 0 0/0 -
1/7 73 TTY 9600/9600 - - - - - 0 0 0/0 -
1/8 74 TTY 9600/9600 - - - - - 0 0 0/0 -
* 1/9 75 TTY 9600/9600 - - - - - 0 0 120/362 -
1/10 76 TTY 9600/9600 - - - - - 0 0 0/0 -
1/11 77 TTY 9600/9600 - - - - - 0 0 0/0 -
1/12 78 TTY 9600/9600 - - - - - 0 0 0/0 -
1/13 79 TTY 9600/9600 - - - - - 0 0 0/0 -
1/14 80 TTY 9600/9600 - - - - - 0 0 0/0 -
1/15 81 TTY 9600/9600 - - - - - 0 0 0/0 -
1/16 82 TTY 9600/9600 - - - - - 0 0 0/0 -
1/17 83 TTY 9600/9600 - - - - - 0 0 0/0 -
1/18 84 TTY 9600/9600 - - - - - 0 0 0/0 -
1/19 85 TTY 9600/9600 - - - - - 0 0 0/0 -
1/20 86 TTY 9600/9600 - - - - - 0 0 0/0 -
1/21 87 TTY 9600/9600 - - - - - 0 0 0/0 -
1/22 88 TTY 9600/9600 - - - - - 0 0 0/0 -
1/23 89 TTY 9600/9600 - - - - - 0 0 0/0 -
1/24 90 TTY 9600/9600 - - - - - 0 0 0/0 -
1/25 91 TTY 9600/9600 - - - - - 0 0 0/0 -
1/26 92 TTY 9600/9600 - - - - - 0 0 0/0 -
1/27 93 TTY 9600/9600 - - - - - 0 0 0/0 -
1/28 94 TTY 9600/9600 - - - - - 0 0 0/0 -
1/29 95 TTY 9600/9600 - - - - - 0 0 0/0 -
1/30 96 TTY 9600/9600 - - - - - 0 0 0/0 -
1/31 97 TTY 9600/9600 - - - - - 0 0 0/0 -
322 322 VTY - - - - - 0 0 0/0 -
323 323 VTY - - - - - 0 0 0/0 -
324 324 VTY - - - - - 0 0 0/0 -
325 325 VTY - - - - - 0 0 0/0 -
326 326 VTY - - - - - 0 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
2-65, 98-321
I created:
int loopback 199
ip add 1.1.1.1 255.255.255.255
ip host SW1 2009 1.1.1.1
Then I try this and fail:
Trying SW1 (1.1.1.1, 2009)...
% Connection refused by remote host
Am I doing something wrong??? Help??
Correct Answer by Roberto Salazar about 7 years 11 months ago
clear line 75 and try again. BTW, you configuration should be ip host SW1 2075 1.1.1.1 since the octal port 2 is line 75.
Overall Rating: 5 (1 ratings)
Correct Answer
Roberto Salazar Wed, 01/28/2009 - 12:24
cisconoobie Wed, 01/28/2009 - 12:26
#clear line 75
#SW1
Trying SW1 (1.1.1.1, 2075)...
Please advise.
cisconoobie Wed, 01/28/2009 - 12:31
Ok it works now. I needed to put in:
# transport input all
under line 1/0 1/31
Thanks for help!
Roberto Salazar Wed, 01/28/2009 - 12:35
Maybe you have not configure the line for the octal cable. can you post the following:
sh run | beg line
sho line
make sure you have "transport input all" under the line 1/0 1/x
