Common Services 3.1.1
Jan 28th, 2009
Hi experts,
I need deploy "Cisco Works LMS 3.0", the Supported Devices Tables show for routers 7609s required CM 5.0.3.
I can not install CM 5.0.3, first required install Common Services 3.1.1 but the archive dont download area.
cdiaz@magenta.cl Fri, 01/30/2009 - 05:13
Thanks Joe,
LMS 3.0.1 is now intalled, and mi patch status is:
CM 5.0.3
DFM 3.0.3
RME 4.1.1
CV 6.1.7
But now, CV needs the package CAT6000IOS version 30, when install this package the error is:
Number of Packages Selected for Install : 1
For Product(s) : CiscoView
Install Invoked by user : admin
The Package(s) Selected for Install :
Cat6000IOS
WARNING : Cat6000IOS(30.1):Consistency check failed for base package SwitchAddlets
No package(s) to install for : CiscoView
I use MD5-CHECK and the results is OK.
You can help me
Joe Clarke Fri, 01/30/2009 - 10:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need to update your SwitchAddlets package before you can update the Cat6000IOS package.
