Idle time out parameter for Extension Mobility?
Jan 28th, 2009
We have Call Manager 5.1 and we are looking for a way to set Extension Mobility to automatically log out after 15 mins of Idle time. There is nothing listed for this in system- service parameters. Is there a way to set this up?
Any feedback would be greatly appreciated.
Thank you.
Vicky
Overall Rating: 5 (1 ratings)
Jaime Valencia Wed, 01/28/2009 - 12:51
there is no "idle timer" only the force logout after X time since login. what you're looking for of reset some timer based on activity is not implemented in any version
java
if this helps, please rate
