01-28-2009 12:52 PM
01-29-2009 10:22 AM
No. Seed file only supports certain device types.
You'll need to define the device and custom parser entries before you can go to the Security and Monitor device page to add it manually to the appliance.
01-29-2009 09:36 AM
The GSS is not natively supported on MARS. To support it you would need to create a custom parser then add the device as that custom type.
01-29-2009 10:10 AM
Does it hold true for any reporting device, any brand.
By adding the device as custom type, do you mean via seed file.
01-29-2009 10:22 AM
01-29-2009 11:17 AM
Thanks.
Please confirm whether with customer parser method all the device types are supported.
01-29-2009 01:36 PM
Can you elaborate on your request? I'm not quite understanding what you are asking.
