Different subnet masks in the Same vlan
Jan 28th, 2009
I am moving a company's network ip address range from 192.168.1.x/22 to 192.168.1.x/24
(Other VLANS will also be created)
My question is: in the VLAN where now all users and servers exists, i want to start changing manually the Subnet mask of the servers from /22 to /24.
Would it cause any connectivity problem with the remaining users that still has the subnet mask /22?
mahmoodmkl Wed, 01/28/2009 - 13:57
  • Gold, 750 points or more
u can use the other's ip subnet under the same svi but it needs to be as a secondry address.
Mahmood
jorjes1984 Wed, 01/28/2009 - 23:22
Where do u mean the secondary address should be?
i didn't understood well what u mean
Joseph W. Doherty Thu, 01/29/2009 - 05:19
As Mahmood notes, you might be able to define a secondary address (which supports more than one subnet on the same VLAN). However, I'm concerned about the fact you would have overlapping subnets.
I assume you're hoping just to migrate subnet masks. However, moving from /22 to /24, you could have /22 hosts sitting on /24 network or broadcast addresses.
I would suggest moving hosts to a /24 that doesn't overlap with the existing /22.
e.g.
gateway device
interface someEthernet #
ip address 192.168.1.1 255.255.252.0
ip address 192.168.4.1 255.255.255.0 secondary
When you've migrated, remove the /22. At that point you could either make the new /24 the primary, or migrate to another /24 within the original /22 address block.
