MGCP Gateway Config
Jan 28th, 2009
In a normal Pub/Sub situation, how should the MGCP call agent be configured on a gateway with the following commands:
ccm-manager redundant-host <Pub or Sub>
ccm-manager config server <Pub or Sub>
mgcp call-agent <Pub or Sub> 2427
Jaime Valencia Wed, 01/28/2009 - 13:47
ccm-manager redundant-host Pub
ccm-manager config server Sub
mgcp call-agent Sub 2427
if this helps, please rate
morioka Thu, 01/29/2009 - 20:25
Thanks. So what's my problem if the gateways register when I set it up as sub/pub/pub and they don't register when it's pub/sub/sub?
Jaime Valencia Thu, 01/29/2009 - 20:27
check the order in the CUCM group that the GW has assigned
Nicholas Matthews Thu, 01/29/2009 - 20:35
If this is happening you may have something deeper going on.
The gateway should be able to register to either the pub or the sub. If you're having this problem, there's a chance if you register with the sub as primary, and the sub goes down, it will fail to register with the pub.
As far as what your problem may be? It's a little beyond me. Restarting the Callmanager service always seems to fix these pesky little things :)
David Hailey Fri, 01/30/2009 - 20:51
Some additional comments/advice:
ccm-manager config server --> depends on your configuration, it should be set to the server that is the TFTP server for the cluster (just check which server is running Cisco TFTP service)
ccm-manager redundant-host --> In your scenario, the secondary call processing node would be the Pub
mgcp call-agent --> This should be the Subscriber which is the primary call processing node in your scenario.  As stated above, you should also have the Sub set as the first CM in the CM group
What you described as not working may be because you are running TFTP on the Sub so when you set the ccm-manager config server to the Pub, the gateway can't download it's configuration file; therefore, it can't register.
