ASA L2L VPN drops after 8 hours while in use.
Jan 28th, 2009
I have 5 L2L VPN's running off of my Cisco 5520 ASA. One of them is connected to a Juniper NS, at 8 hours the VPN drops and rebuilds while in use, so the user sessions freeze for a minute. Any ideas on how to correct this? Thanks in advance.
Overall Rating: 4 (1 ratings)
PaulWelc Fri, 01/30/2009 - 14:42
I noticed this in the debug logs. Second message is odd as the VPN is in use when it goes down.
Connection terminated for peer x.x.x.x Reason: Peer Terminate Remote Proxy N/A, Local Proxy N/A
Session Type: IPsec, Duration: 8h:00m:25s, Bytes xmt: 1176522, Bytes rcv: 3280246, Reason: Idle Timeout
RicheeJJJ_2 Sun, 02/01/2009 - 12:42
Check your lifetime statements on the crypto isakmp policies. That's how many seconds can go by before security associations re-establish. Also in the crypto map there is a lifetime value which can be set to how many seconds before the tunnel gets torn down or how many kilobytes can pass before the tunnel gets torn down.
PaulWelc Mon, 02/02/2009 - 10:26
Thanks RicheeJJJ my settings look correct I wonder if it is on the other side though he connects to Cisco ASA's.
crypto map SBCVPN 2 set peer x.x.x.x
crypto map SBCVPN 2 set transform-set ESP-3DES-SHA
crypto map SBCVPN 2 set security-association lifetime seconds 86400
crypto map SBCVPN 2 set security-association lifetime kilobytes 4608000
crypto isakmp policy 5
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
