Call Forward using a code
Jan 28th, 2009
Standard users are configured with the ability to call forward to internal extension only.
Certain users will have the ability to forwrad calls to there mobiles.
To invoke the call forward the users will be given a code e.g #1234, this needs to translate to there mobile number.
This will be for a very limited set of users.
What is the best way to do this on CUCM 6.1?, can I use client matter codes.
Jaime Valencia Wed, 01/28/2009 - 14:34
CMC and FAC require someone to dial them, so no good to CFA.
you can limit this with a translation pattern for #1234 and only those users can reach the partition were you configured it
java
if this helps, please rate
