iPhone fails to authenticate within ACS.
Jan 28th, 2009
Hi There!
I have created a VPN group (PIX v8.0(3))to the corporate iPhones, they work fine if the authentication is LOCAL, but if I request them to authenticate within ACS, it fails. What should I do?
j.conceicao Thu, 01/29/2009 - 04:48
So far it is.
Yes, I have added the PIX in the ACS. I have about 300 L2L Dynamic connection, 3 PIX x PIX/ASA and about 150 remote access.
Here is the set pointing to ACS:
aaa-server PIX protocol radius
aaa-server PIX (Corp) host 10.0.30.3
timeout 5
key auditor
j.conceicao Thu, 01/29/2009 - 07:35
This group has access via remote VPN and via iPhone.
Here is mu configuration:
object-group network Painel
network-object 172.30.23.0 255.255.255.0
access-list Outside_cryptomap extended permit ip any object-group Painel
access-list Corp_NAT_0_out extended permit tcp host 10.0.30.102 object-group Painel eq 7778
access-list Corp_NAT_0_out extended permit tcp host 10.0.30.109 object-group Painel eq www
access-list Corp_NAT_0_out extended permit tcp host 10.0.30.169 object-group Painel eq 8080
access-list Corp_NAT_0_out extended permit tcp host 10.0.30.191 object-group Painel eq 8080
access-list Corp_NAT_0_out extended permit tcp host 10.0.30.235 object-group Painel eq www
access-list Corp_NAT_0_out extended permit tcp host 10.0.30.253 object-group Painel eq www
access-list Painel_SplittunnelAcl standard permit host 10.0.30.102
access-list Painel_SplittunnelAcl standard permit host 10.0.30.109
access-list Painel_SplittunnelAcl standard permit host 10.0.30.169
access-list Painel_SplittunnelAcl standard permit host 10.0.30.191
access-list Painel_SplittunnelAcl standard permit host 10.0.30.235
access-list Painel_SplittunnelAcl standard permit host 10.0.30.253
ip local pool PainelACCESS 172.30.23.1-172.30.23.254 mask 255.255.255.0
group-policy Painel internal
group-policy Painel attributes
vpn-tunnel-protocol IPSec l2tp-ipsec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value Painel_SplittunnelAcl
tunnel-group Painel type ipsec-ra
tunnel-group Painel general-attributes
address-pool PainelACCESS
authentication-server-group PIX
authorization-server-group PIX
accounting-server-group PIX
default-group-policy Painel
tunnel-group Painel ipsec-attributes
pre-shared-key *
