is-is or ospf
Jan 28th, 2009
hello,
how can I compare is-is and ospf protocols in service providers' network ?
which one of these two protocols is used in service rpoviders' network mostly and why ? and
why service providers are moving from ospf to is-is ?
please explain me these..
thank you.
Mohamed Sobair Thu, 01/29/2009 - 20:01
There are lots of details about that..
But the basic concept as follows:
1- ISIS is OSI developed standard Operates at layer-2 while OSPF operates at layer-3.
2- Both represents Link state Protocols.
3- Both represent a Backbone Area, Area 0 in OSPF while Level-2 in ISIS.
4- Both requires hierarchal Design.
5- ISIS uses TLvs while OSPF uses LSAs.
6- Each ISIS router require a unique NSAP Address.
7- Every OSPF Area builds its own link state Database.
8- ISIS builds 2 seperate Dtabases, Level1 Database & Level2 Database.
9- Every ISIS level-1 router (Stub) has a default route toward level-2 to reach another level-1 ISIS router.
10-ISIS TLvs 122, 33 , 135 carries Wide Metric.
11- ISIS illustrates (DIS) in a Multiaccess Segment, There is no Backup DIS , while OSPF illustrates (DR and BDR).
The most Routing protocol Used by the Service Providers is ISIS because Of its simplicity and its Structure maintained throughout different type of Config.. Ie: Redistribution into ISIS doesnt change the main Structure For ISIS protocol while Doing the Same in OSPF changes its main structure.
Mohamed
jai231555 Mon, 02/02/2009 - 10:47
hi,
can you name any ISP which moved from ospf to isis. or
how can I contact an ISP ?
tahnk you.
