VPN Client communication
Jan 28th, 2009
I have a VPN Concentrator 3020 and remote clients using the VPN Client. Is it possible for the clients connected to the concentrator to exchange traffic between them? The challenge that I see is that the traffic from a client arrives to the concentrator on the public interface and it should go back through the same interface. So, anybody tried this before?
JORGE RODRIGUEZ Wed, 01/28/2009 - 19:10
  • Green, 3000 points or more
Titus,
Absolutely they can communicate one another through the IPsec tunnel , say if your RA clients IP Pool is 172.16.1.0/24, RA client_1 connects to your VPN concentrator and gets IP 172.16.1.50 and Subsequently RA client_2 connects and gets IP 172.16.1.51 they will be able to ping each other as well as exchnage data RDP or copy files etc.. as long the RA clients PCs do not have any firewalls turned on.
ticonaru Thu, 01/29/2009 - 15:16
That's not what I see in my implementation. I can ping each client from the 3000 concentrator, but one client can not ping the other. Is there any configuration that needs to be added to either the concentrator or/and the VPN clients?
Thanks.
