ACE vs CSS (or CSM!)
Jan 28th, 2009
I really thought that the Cisco EOL CSS and replaced it with ACE.
It seems that CSS is still very much alive and being sold. How would you compare CSS to ACE? Features, Design, Cost, Licensing ..etc
When I compare these two - few things that jump out are:
CSS1500s - up to 40GB throughput
4710 ACE - up to 4GB throughput
Module ACE - up to 64GB throughput
So right away - if I needed appliance that could handle 20GB throughput I would need to go with CSS.
ACE - context supported
CSS - not supported (didn't find it being supported)
So again - if I need an environment with multiple virtual contexts, I would need to go with ACE.
CSS, CSM, ACE .. too many choices!
thoughts?
Thank you
Overall Rating: 5 (3 ratings)
veriton Fri, 01/30/2009 - 07:59
Are CSS11500's EOL? Any EOL announcement is not mentioned here:
http://www.cisco.com/en/US/products/hw/contnetw/ps789/prod_eol_notices_list.html or on the CSS 11500 page:
http://www.cisco.com/en/US/products/hw/contnetw/ps792/index.html
The CSS 11500 products have served me well at a number of customers and I think competes well with F5 BIG-IP, certainly at the smaller end of the enterprise market. I can't comment on virtual contexts though.
Collin Clark Fri, 01/30/2009 - 09:39
I'm sure the EoL is coming (since the introduction of the ACE), but I have not heard of any dates. We have both in our environment and the ACE blows away the CSS in features, config, etc. We're planning on removing all CSS's and going to just the ACE. The ACE (in our configurations) are quite a bit cheaper. The FO is better, the multiple contexts is just plain cool, even the WebUI (which I normally don't like) is nice and easy, and ACL's actually work with the ACE. I heard that Cisco hired some MAC GUI developers to help in the design of it. My vote is for the ACE, it's not even close.
Gilles Dufour Tue, 02/03/2009 - 05:48
There is indeed no EOL annoncement for the CSS11500. Not sure when it will come. Probably not in the next 6 months (but no guarantee).
Indeed the CSS does not have virtualization.
It is also lacking the dynamic cookie stickyness. It does not have the caching and http optimization offered by the ACE appliance. Only limited DoS protection on the CSS vs large Firewall features on ACE.
No HW module required for SSL/Compression support on the ACE appliance.
No HTTP header insert function on the CSS.
G.
vpetracca Tue, 02/10/2009 - 03:51
Hi Gilles.
I'm going to do a migration from CSM to ACE Service Modules.
Before doing it i would like to make a good presentation to the customer on what are the main differences between these two product.
I'm not talking about hardware , capacity virtualization and so on.
Customer would like to know major differences between configuration option like predictor ( new predictor or something like that..), probes , serverfarm options...
etc..
Something that you know it is possible to do with Ace and not with csm and that can be useful for the customer or that can impress ..
Thanks in advance.
Vittorio
Syed Iftekhar Ahmed Tue, 02/10/2009 - 12:22
Features Not available in CSM
SIP loadbalancing
Connection rate limiting per VIP and per Real
SNMP based LB decisions (CPU,mem,disk space)
Least bandwisth predictor
Virtualization
TCP Reuse
Http Compression
Http optimzation
TCP/IP Normalization
Http,DNS,Ldap,Rtsp,ICmp,SIP,skinny fixups
Configuration checkpoints
Syed
Syed Iftekhar Ahmed Tue, 02/10/2009 - 13:49
Correct.
I mixed up ACE module with ACE appliance.
As per Cisco Http Compression is committed for ACE module.
I am not sure if HTTP optimization will be available on ACE module.
Syed
vpetracca Wed, 02/11/2009 - 00:58
Thanks Syed for the informations.
Another question..
In the actual CSM configuration
that we are going to migrate we use this basic type of configuration for Vservers :
real name A
ip address x.x.x.x
inservice
real name B
ip address x.x.x.x
inservice
probe TCP tcp
interval 30
retries 4
failed 15
serverfarm SF
real name A
inservice
real name B
inservice
probe TCP
vserver VIP
virtual V.V.V.V tcp www
serverfarm SF
advertise active
persistent rebalance
inservice
So basically we put the tcp port value only on the vserver object . And this is inherited
by all the other objects..
Is it possible to do the same ( or similar) with ACE ?
Syed Iftekhar Ahmed Wed, 02/11/2009 - 01:21
Destination ports will not get translated until you use "rserver under Server Farm definition.
Only exception is that in ACE Module you have to define port under probe. If you donot define port it doesn't inherit the port number of the real server.
(The above mentioned functionality is available in ACE appliance.Probe defined in Ace Appliance does inherit port number form real).
Your CSM config will translate into ACE as follows
probe tcp TCP80
port 80
interval 30
faildetect 4
passdetect interval 15
receive 4
open 4
rserver host A
ip address x.x.x.x
inservice
rserver host B
ip address x.x.x.x
inservice
serverfarm host SF
probe TCP80
rserver A
inservice
rserver B
inservice
parameter-map type http VIP_HTTP
persistence-rebalance
class-map match-all VIP
match virtual-address V.V.V.V tcp eq www
policy-map type loadbalance first-match VIP
class class-default
serverfarm SF
policy-map multi-match POLICYxyz
class VIP
loadbalance vip advertise active
appl-parameter http advanced-options VIP_HTTP
loadbalance policy VIP
loadbalance vip inservice
loadbalance vip icmp-reply active
Syed Iftekhar Ahmed
vpetracca Wed, 02/11/2009 - 02:39
So the only solution with Ace
module is to create many different probes...Correct?
Thanks a lot
Vittorio
Gilles Dufour Wed, 02/11/2009 - 03:42
Syed,
man!!! I just discovered the module didn't have inheritance.
I found the code diff that was added to the appliance and indeed it is not in the module.
I will make sure this code is added quickly to the module.
It should work in A2(1.5)
Gilles.
vpetracca Wed, 02/11/2009 - 03:51
Hi Gilles ..
Are you talking only about ACE appliance ? Correct ?
About ACE module "inheritance" will never be possible ?
Customer is using it a lot on CSM...to have a shorter config file..
Vittorio
Syed Iftekhar Ahmed Wed, 02/11/2009 - 13:52
Yes you need to create probes for each unique port in ACE Module.
Gilles is talking about inheritance in ACE module. After the code mentioned by Gilles, Ace module's probes will be able to inherit port numbers from reals.
Syed Iftekhar Ahmed
vpetracca Thu, 02/12/2009 - 00:48
Hi Syed.
First of all thanks for all the informations your are giving..
We will use 3.0.0_A1_6_3c Ace software version.
So are you telling me that it is possible to use on ACE Service Module inheritance on probes ?
Have a nice day
Vittorio
Syed Iftekhar Ahmed Thu, 02/12/2009 - 01:16
Vittorio
We are moving in circles:)
No you got it wrong. Probe inheritance is not a feature in any of the current "ACE Module" code. Gilles promised that it will be available in a future release.
Currently only ACE appliance supports this feature.
In summary
Probe Inheritance is not supported in ACE Module (In future we will get it).
Syed
vpetracca Thu, 02/12/2009 - 01:26
Sorry for the misunderstanding.
Ok Syed.
Great informations from you and Gilles.
Can i make the last question ?
I prefer to ask you before doing it.
Just tell me if i can.
It is about a CSM variable called ROUTE_UNKNOWN_FLOW_PKTS !
Vittorio
Syed Iftekhar Ahmed Thu, 02/12/2009 - 01:42
The variable you mentioned is mostly used in one arm mode.It is used to allow the CSM to
handle "server-initiated flows" or "connections which bypass
the CSM" - e.g. when opening an HTTP connection to a real server bypassing the
for such scenarios "variable ROUTE_UNKNOWN_FLOW_PKTS 2" is used in CSM
If this variable value is not set, the CSM would drop such connections because the initial
SYN was never seen by CSM.
For more details
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/ServerFarmSec_2.1/5_CSM.pdf
In one-arm mode ACE to achieve this you need to turn off normalization
for e.g
interface vlan xxx
ip address 10.1.1.1 255.255.255.0
alias 10.1.1.3 255.255.255.0
peer ip address 10.1.1.2 255.255.255.0
no normalization <----------------------*****
Syed Iftekhar Ahmed
vpetracca Thu, 02/12/2009 - 02:01
You perfectly understand my needs.
What you described is the actual CSM configuration.
When we installed the CSM customer preferred to use One-Arm mode with the variable ROUTE_UNKNOWN_FLOW_PKTS 2
because he doesn't want the CSM to be the default-gateway for servers.
So also ACE ( if i don't put NO NORMALIZATION on interface Vlan) will drop connections which initial SYN was never seen by ACE ?
vpetracca Thu, 02/12/2009 - 03:14
I'll be working on lab simulating the migration from CSM to ACE.
All the informations you gave to me will be very useful.
I think i'll will continue this discussion when i'll have some new questions based on direct experience on my lab.
Bye and thanks again.
Vittorio
vpetracca Mon, 02/16/2009 - 07:59
Hi Syed..
I've been starting my lab..
A question :
Two context :
1 - "Production" where there will be the " production VIPs"
2 - "Test" where there will be "testing VIPs"
We will "limit-resource all"
A right or better configuration for for create resource-class:
1) Admin Context
2) Production context
3) Test Context
Basically the question is :
if we don'use Admin context to create Vips how much is better to limit the resource allocated for this context ( minimum e maximum)..
I know that you should know customer enviroment but ..Some hints & trips ?
Thanks a lot
Vittorio
Syed Iftekhar Ahmed Mon, 02/16/2009 - 16:43
A common misconfiguration I have seen is that people forget to reserve resources for Admin contexts.
Admin context is assigned to default resource-class
(with no minimal resource defined ) and this makes it suseptible to situations
where there are no resources available for Admin context.
If your Admin context is just for admin purposes (no LB traffic)
then there should be 1% to 5% resources reserved for Admin context.
Its recommended that new ACE installations do not exceed 60 to 80 percent of the module's total capacity.
To accomplish this goal you can create a reserved resource class with a guarantee of 20 to 40 percent of
all the ACE resources and configure a Dummy virtual context dedicated solely to ensuring that these resources are reserved.
With this Dummy context ( Resources assigned but not used) gives you a buffer of resources that can be used
If some of the existing contexts require more resources due to traffic increase.
Syed Iftekhar Ahmed
vpetracca Wed, 02/18/2009 - 05:12
Hi Syed
I'm continuing my lab and so new questions..
Now I would like to talk about sticky with two question :
1) " sticky-Limits the number of entries in the sticky table. You must configure a minimum value for sticky to allocate resources for sticky entries, because the sticky software receives no resources under the unlimited setting" .
So if I create a resource- class with limit-resource all , sticky have no resource available ?
2) How many sticky group can I create in a context ?
Have a nice day and thanks for all your answers and advises.
Vittorio
vpetracca Fri, 03/06/2009 - 01:36
Hi Syed.
I'm always working on lab , migrating from CSM to ACE Module.
Customer used to do stickyness based on cookie insert by the CSM.
Now i'have a question.
The cookie created by ACE can be a Session cookie ( broowser expires) or can a a validity time.
How can i set the validity time of the cookie in ACE ?
We do it on CSM with a variable..
Thanks Vittorio
Syed Iftekhar Ahmed Tue, 02/17/2009 - 09:41
With probe inheritance, you dont need to define port number in probe definition. Probe inherits it from the real server port.
It enables you to create a single probe and assign it to multiple Serverfarms.
Syed Iftekhar Ahmed
