UC520 crash
Jan 28th, 2009
I have a client with a UC520 box less than twelve months old that has crashed three times since September.
I have the crashinfo files for each occurrence but am at a total loss what to with them. The client has just purchased a smartnet contract, but I find it frustrating that they have to purchase a support contract for a problem with a brand new system.
What can I do with the crashinfo to see what may be causing the crash.
Damian Halloran
Overall Rating: 5 (2 ratings)
Paolo Bevilacqua Thu, 01/29/2009 - 03:44
start upgrading to latest UC520 software, if it happens again you ill then investigate.
Notes, supposedly you're a Cisco partner, you should be in a position to update your clients UC520 at any time.
Nicholas Matthews Thu, 01/29/2009 - 06:05
Hi Damian,
I do know know of any specific UC520 crashes off hand, but we've fixed probably nearly 200-300 crash bugs between the 12.4(11)XW train and 12.4(22)T.
If you have any tracebacks or errors messages, I would put them into the Cisco Output Interpreter (not sure if it takes crashinfo files as input or not), and see what it spits out.
I find that it's pretty helpful. I have access to the same stuff, but this tool is even faster:
https://www.cisco.com/cgi-bin/Support/OutputInterpreter/home.pl
hth,
nick
Damian Halloran Thu, 01/29/2009 - 14:06
Hello and thanks to both of you for your replies.
The upgrade to IOS was I suppose something I should have expected and will do so very soon.
I did put the output through the output interpreter - fantastic tool.
The specific error that it came up with was:
ERROR MESSAGE NOTIFICATIONS (if any)
%SYS-2-INTSCHED (x115): '[chars]' at level [dec]
Explanation: An internal software error has occurred.
Which points me to a programming error which points to a needed IOS upgrade.
Thanks again.
