Wireless LAN Controller
Jan 28th, 2009
I will start off by saying that i only have experience with small - scale (2106 WLAN Controller)unified wireless network setup. So, i was wondering what factors do i need to take into consideration while setting up a Medium - Large scale Unified wireless network (For ex. How many AP's do i require for a 3-4 storied building?). Also which Controller and Access Point is recommended for such a scenario. I need the Controller to support Mesh networking and 802.11N.
Thank in advance for you time.
Sri
Overall Rating: 4 (1 ratings)
Scott Fella Thu, 01/29/2009 - 05:46
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I would suggest a site survey to determine the location and amount of ap's you will need. Also the engineer will tell you what model ap and antennas he or she suggest. As for controllers, depending on how many ap's is required, the WLC4400 with the 5.2 code will allow you to use the wlc to support the mesh ap's also. Now depending again on the survey, you can use the 1252 or 1142 ap's which currently support 802.11N draft 2.0.
sdeva1986 Thu, 01/29/2009 - 09:21
Thank you for the reply. I have one more question relating to what you mentioned. When you say site survey done by the engineer does the survey involve a set of procedure (if yes, then what kind?) or is it through experience that he determines how many AP's are required?
Scott Fella Thu, 01/29/2009 - 09:33
  • Hall of Fame,
    2017 Wireless
It does involve certain requirements depending if you require data, voice or location. It also depends on devices and applications that will be utilizing the WLAN. Engineer experience does play a big factor. He or she might be familiar in an environment like yours and might know what to look for and what will and will not work. If he or she understands RF, your deployment will be successfull. If not, then you will hate it as much as the user will.
mark.cronin Thu, 01/29/2009 - 12:08
Fella mentioned location
have you considered IDS and IPS?
Are you concerned with tracking
802.11a 5ghz
802.11b 2.4ghz
802.11g 2.4ghz
802.11n 2.4ghz - 5ghz
Rogue access points internal and external to
your building?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
