Voice packets through 1310 Wireless bridge pair
Jan 28th, 2009
I have deployed a pair of 1310 in bridge mode and data are passing through OK. the two bridges are connected to trunk ports of cisco switched on both sides. In order to pass voice through the bridge, do I need to configure voice Vlan's in the 1310 as well? I believe that because it is bridge (emulating a cable) I don't need to configure any vlan in 1310. all Vlan tagging is made from the switch, is that right
Thank you in advance
steliosgk Mon, 02/09/2009 - 02:40
The problem remains. I cannot make 3 different Vlans (10, 20, 30) pass through the wireless bridge.
the wireless bridge is set uo with SSID bridge, and it is the only SSID that exists.
