01-29-2009 12:13 AM - edited 03-04-2019 01:01 AM
I am trying to work on the Cisco Packet tracer 5.0 for some time now.. But everytime i configure an interface and then verify it show the "show" command. I am getting an information displayed that says the port is disabled .. Can anyone please provide me with the solution for this problem. For a better view of the problem please check the attachment.
Solved! Go to Solution.
01-29-2009 12:37 AM
Hello Vishal,
by default interfaces are admin down
do
int ser1/0
no shutdown
to be able to use it
Hope to help
Giuseppe
01-29-2009 12:37 AM
Hello Vishal,
do
int ser1/0
no shutdown
Hope to help
Giuseppe
01-29-2009 12:44 AM
01-29-2009 01:08 AM
Hello Vishal,
now is different the serial interface is down/down
before it was admin down/down.
A serial interface to be up/up needs to be connected to some device that makes leads to be up:
at the end of the show you see:
DCD down carrier
DSR down
CTS down
these are from L1 DCE
DTR and RTS are from the router serial interface
see the following from a router in production
sh int ser4/2
Serial4/2 is up, line protocol is up
446 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
if you are connecting two routers in back-to-back one has to provide clock:
use
clock rate 2000000
Hope to help
Giuseppe
01-29-2009 12:37 AM
by default all ports are disabled.
you must go under the port and use the command "no shutdown"
then the port will be activated.
