Unity Connection 7.0 Notification Message
Jan 29th, 2009
Using Unity connection 7.0 is it possible to change the Date format of SMTP notifications of new messages. By default it's MM/DD/YY and customer would like DD/MM/YY.
Thanks for your help.
gmarkiewicz Fri, 06/18/2010 - 03:26
Did anybody find fix for that problem?
I'm using Unity Connection 7.1 and have same problem as above.
I've uploaded from Cisco and changed network locale, language and all relevant settings that I could find, but it is still in MM/DD/YY format which is not used in Europe. The only option that I cannot change is Default User Locale in Enterprise Parameters. It is set to English United States, but it is only option. I couldn't find any packet for Unity Connection to change that as well.
David Hailey Fri, 06/18/2010 - 21:49
I've never seen a parameter to change this setting in CUC so I believe the answer, while it may not be desired, is no.
