OIR 6500 & 7600
Jan 29th, 2009
I'd like to know about OIR in the 6500 and 7600 series, if the configuration remain at NVRAM or I need to set anything to erase the configuration when I remove a module or a SPA.
Giuseppe Larosa Thu, 01/29/2009 - 03:27
  • Hall of Fame,
    Founding Member
Hello Paulo,
configuration will be kept in RAM ready to be reused if the same module or a module of same hardware is reinserted in the same slot.
Hope to help
Giuseppe
PauloHirakawa Thu, 01/29/2009 - 03:44
Hello Giuseppe,
Thanks for your help. Do you know how can I erase the configuration if I don't put another module at the same slot? This procedures can be applyed to SPAs in the same way as the normal modules?
Thanks again.
