Update password
Jan 29th, 2009
Dear All,
i need to make a service to update the pin of the user,
can any one help me in the sql update command to do this .
stephan.steiner Fri, 01/30/2009 - 00:01
You can't use SQL directly (well, theoretically you can but then the user won't be able to log in anymore since the password is stored in encrypted form and there's no way for you to turn a regular password into the encrypted version).
What you can do though is use the updateUser AXL command to set a new pin - that works just fine.
marwa_ads Fri, 01/30/2009 - 02:53
Thanks Stephan,
But actually i don't know how to use the updateUser AXL command to do so,
can you tell me how to use it?
