Trouble forwarding between 7600 and 6500
Jan 29th, 2009
Hi!
I have 7600 config:
gw#sh run int gi1/31
Building configuration...
Current configuration : 175 bytes
interface GigabitEthernet1/31
switchport
switchport trunk native vlan 6
switchport trunk allowed vlan 6
switchport mode trunk
end
gw#sh run int vlan 6
Current configuration : 140 bytes
interface Vlan6
ip address 1.2.3.9 255.255.255.248
no ip redirects
no ip proxy-arp
ip pim dr-priority 2
ip pim sparse-mode
end
and 6500:
core#sh run int gi5/1
Current configuration : 217 bytes
interface GigabitEthernet5/1
core#sh run int vlan 128
Current configuration : 202 bytes
interface Vlan128
ip address 1.2.3.10 255.255.255.248 secondary
no ip redirects
no ip proxy-arp
end
Pings from "gw" to "core":
gw#ping 1.2.3.10
Sending 5, 100-byte ICMP Echos to 1.2.3.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
But from another side ("core" to "gw"):
core#ping 1.2.3.9
Sending 5, 100-byte ICMP Echos to 1.2.3.9, timeout is 2 seconds:
Success rate is 0 percent (0/5)
VLANs is directly connected.
Yudong Wu Thu, 01/29/2009 - 10:26
  • Gold, 750 points or more
Can you try extend ping by specifing source IP as 1.2.3.10 when you ping from "core" to "gw"?
mkachalin Fri, 01/30/2009 - 00:31
core#ping
Protocol [ip]:
Target IP address: 1.2.3.9
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 1.2.3.10
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Packet sent with a source address of 1.2.3.10
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
It seems, that "core" used first ip address on interface to send reply to "gw", when trying to use ordinary ping. Where is the root of problem, or it's normal behaviour?
Yudong Wu Fri, 01/30/2009 - 07:38
I am not 100% sure if it is the same on all platform. Here is a comment from someone else "An ICMP echo request will be generated by the router itself. In the assembly of the ICMP message by the router, the Source ip address that is used in the creation of the resulting ip ICMP message will be the primary ip address for the interface or sub-interface that the datagram is to be transmitted on. As an aside, routers never generate ip datagrams that use a SECONDARY ip address that may be attached to an interface. It will always use the PRIMARY address."
Roberto Salazar Thu, 01/29/2009 - 11:43
The core's interface gig 5/1 is not even a switchport per your show run:
So, the ping from core to gateway I understand why it will fail. But from gw pinging to 1.2.3.10 suggests there is another host responding to that ip address. can you look at show ip arp 1.2.3.10 from the gw and trace where the mac is learned from with "show mac address-table ".
mkachalin Fri, 01/30/2009 - 00:40
I apologise. There is full config, when I've posted config made it with no attention.
switchport
switchport trunk native vlan 128
switchport trunk allowed vlan 128
end
