Cisco 2960 IP Address conflict
Jan 29th, 2009
We have the following setup in our DataCentre and experience IP conflicts with the HSRP address. On the 2960 is 1 VLAN connected to a Catylyst 4000 switches with HSRP enable for the gateway of clients on the 2960. The probem we experience is customers on the 2960 switch add the HSRP address as a secondary IP on their Network connection and all traffic will route to their servers. Is there a way to prevent customers to use the HSRP address on their servers ? We have setup access list for each interface but this seems to happen on layer 2.
mark.cronin Thu, 01/29/2009 - 08:37
David
Can you send a config of the 2960 and the 4000 - remove any security info
Can you send a diagram
Mark
davidmalan Thu, 01/29/2009 - 09:11
I have attached the digram with basic connections and setup.
Cisco 2960
hostname xxxxxxxxxxxxxxxxxxxxxxxx
logging buffered 200000 debugging
username xxxxxxxx privilege 15 password xxxxxxxx
username xxxxxxxxx privilege 15 password xxxxxxxxx
aaa new-model
aaa group server radius
no ip domain-lookup
no file verify auto
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
vlan internal allocation policy ascending
vlan 2
name ***Vlan_ABC_Local_LAN***
vlan 200
name xxx_management
vlan 210
name PDU-Management
vlan 845
name xxxx-Server-Vlan
interface FastEthernet0/1
description *** PDU 1 ***
switchport access vlan 210
switchport mode access
switchport port-security maximum 2
speed 10
duplex full
no cdp enable
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
interface FastEthernet0/2
description *** PDU 2 Bottom ***
speed 10
duplex full
no cdp enable
interface FastEthernet0/7
description *** Not In Use ***
switchport access vlan 845
ip access-group 7 in
speed 10
duplex full
no cdp enable
interface FastEthernet0/8
ip access-group 8 in
speed 10
duplex full
no cdp enable
interface GigabitEthernet0/1
description *** Link to cat 4000-01 *** UPLINK to CAT4000
switchport trunk allowed vlan 210,845
switchport mode trunk
speed 100
duplex full
interface GigabitEthernet0/2 UPLINK to CAR4000
description *** cat 4000-02 ***
speed 100
duplex full
spanning-tree cost 20
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
shutdown
interface Vlan200
description ***Management Vlan ***
ip address XXXXXXXXXXXXXXXX
no ip route-cache
interface Vlan845
no ip address
no ip route-cache
ip default-gateway
no ip http server
ip radius source-interface Vlan200
logging facility syslog
access-list 1 remark ***Management ***
access-list 1 permit XXX.XXX.XXX.XXX
access-list 1 deny any log
access-list 5 permit XXX.XXX.XXX.XXX
access-list 6 permit XXX.XXX.XXX.XXX
access-list 7 permit XXX.XXX.XXX.XXX
access-list 8 permit XXX.XXX.XXX.XXX
Cat4000
interface GigabitEthernet5/2
description *** 100mb Link to Int Gi0/1 ***
switchport nonegotiate
speed 100
duplex full
udld port
spanning-tree guard root
Tshi M Thu, 01/29/2009 - 09:40
  • Silver, 250 points or more
I am a bit confused with the diagram. It appears that you are using one of the top switch VLAN845 address as the standby address on the bottom switch vlan845. And also both VLAN have the same priority.
Edison Ortiz Thu, 01/29/2009 - 12:03
  • Hall of Fame,
    Founding Member
You should look into implementing Dynamic ARP Inspection:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.1/19ew/configuration/guide/dynarp.html
HTH,
__
Edison.
davidmalan Fri, 01/30/2009 - 01:33
Sorry for the incomplete diagram, I have removed most of the config and IP address information. Your diagram is correct in the setup we currently have setup, the solution and setup work fine but the main problem are customers change their IP information on their servers (connected to the 2960 switch )to the HSRP address, and all traffic will route to the server with the default gateway (HSRP address) configured on that server.I have checked the Cisco website and couln't find information to configure dynamic arp inspection on a 2960 switch. The CAT 4000 just acts as a default gateway on the VLAN interface. So ,if someone configure the ip address 10.0.0.1 (HSRP address) as a secondary IP on their server it would route traffic to their server (referring to your diagram)
Edison Ortiz Fri, 01/30/2009 - 06:39
  • Hall of Fame,
    Founding Member
2960 is a Layer2 switch so it's not involved on any Layer3 decision in your network. The configuration must be done in the 4500 switch as it's the only device acting as a Layer3 device.
HTH,
__
Edison.
