SNMPc display HOSTNAME rather than IP address
Jan 29th, 2009
I have a closed network architecture that uses a satellite network as transport. My centralized SOC is located behind a Multicontext Transparent VFW architecture using ASA 5510. I am populating my SNMPc maps by allowing the NMS to contact the FW via the outside interface (security level 0).
SNMPc is seeing all the LOCAL contexts via the IP HOSTNAME of the FW context.
SNMPc is seeing all the REMOTE contexts via the IP address of the FW context, but will not populate the context via the HOSTNAME assigned to the context.
The following is an example of the SNMP configuration for a context.
hostname <DEVICE HOSTNAME>
snmp-server host <outside interface> <NMS_MGR_IP_ADDRESS> community <COMMUNITY_STRING_VALUE> version 2c
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
snmp-server enable traps syslog
snmp-server enable traps remote-access session-threshold-exceeded
tstanik Wed, 02/04/2009 - 06:43
You need to do is to setup your device to send SNMP link up/down trap to DFM. Once
DFM got the info, it will show in the monitoring console. To do that, you need to
configure the below.
snmp-server enable traps snmp linkup linkdown
snmp-server host x.x.x.x traps public snmp
where x.x.x.x is the ip of your DMF. This will make the router to send the link up/down
trap. Once DFM receive the trap, it will display it at the monitor console. This will be a
work around for you if you don't have ICMP turn on but still want the link up/down
detection.
