DCR - error in communication channel
Jan 29th, 2009
  • Bronze, 100 points or more
We use LMS 3.1 with the available patches installed.
I wanted to configure some device credentials and identities.
After clicking "Apply" the following error was displayed:
"Internal error in communication channel."
I attached the dcr.log for further information.
Joe Clarke Thu, 01/29/2009 - 07:52
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I don't see any errors in this dcr.log. There may be errors in the dcrclient.log. However, if the server is on Windows, make sure you do not have on-access virus scanning enabled for the NMSROOT directory. If you do, disable this, and restart Daemon Manager. This problem should go away.
Sven Hruza Thu, 01/29/2009 - 09:04
We don't use a virus scanner on the machine.
I enabled the debugging for DCR and attached the dcrclient.log and dcr.log.
If you please have a look on the files?
Thanks!
Sven Hruza Thu, 01/29/2009 - 09:34
Thanks for the fast reply!
I thought I installed the patch, but I will check it once again.
bm_5789 Sat, 02/07/2009 - 09:08
I am seeing the same error when I try to edit Device Credentials for my devices. I am confused about which patch I am supposed to install. Would you mind giving the exact name and date of the patch. I would appreciate that. TIA
Joe Clarke Sat, 02/07/2009 - 10:31
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It's the patch with CSCsu84143 in its name. Just pick the one for your platform (either Windows or Solaris).
bm_5789 Sat, 02/07/2009 - 10:47
That's what I was afraid of...I installed that patch last week due to a Device discovery problem. I'm not sure what to do now.
Joe Clarke Sat, 02/07/2009 - 10:56
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Then start a new thread for your issue.
p.woydig Wed, 02/24/2010 - 04:23
Hello!
I am having the same problem - sometimes I get the error message - sometimes not.
I am having on-access virus scanning enabled and do not want to disable the scanning on the NMSROOT directory.
Can you tell me the name of this process that causes this conflict?
Then I could disable the virus scanner for this process!!
Thanks!
