JORGE RODRIGUEZ Fri, 01/30/2009 - 04:07
  • Green, 3000 points or more
Angelo, yes you can terminate SSL vpn in your PIX525 as long it meets the requirements in running code 7.x above, PLS have a look at the link I provided in my previous post SSL/VPN session.
ANGELO DE MASI Fri, 01/30/2009 - 04:16
thanks a lot for ur quick reply.
I have taken a look at that link u posted, but there are only links regarding ASA. Which one of them I shold have to consider for PIX? Could you pleas help me? Thanks in advance again for your collaboration.
Bye
JORGE RODRIGUEZ Fri, 01/30/2009 - 12:53
What code is your PIX525 running? if you are runnign code 7.x or above you can use ASA configuration examples from the link given.
ANGELO DE MASI Sat, 01/31/2009 - 02:32
My PIX is running 6.3(5) code and I'm upgrading it to 7.1 next week. Could I keep my ipsec vpn and configure ssn vpn at the same time?
thank you very much
bye
cisco24x7 Sat, 01/31/2009 - 14:14
  • Silver, 250 points or more
Jorge,
You "can" terminate SSL VPN on the Pix?  When did cisco allow this?
JORGE RODRIGUEZ Sat, 01/31/2009 - 20:58
David,  good catch,       solid 5 !!     .
Yvann,  My apologies  I have checked  7.x   and above  releases for PIX , seems  PIX do not support Webvpn . You will need  ASA applience .  However  this should not hold you from upgrading 6.3 to 7.x as there are other reach features you can take advantage of .
If you have not yet check  upgrade check list go over these two links
http://www.cisco.com/cgi-bin/tablebuild.pl/pix">http://www.cisco.com/cgi-bin/tablebuild.pl/pix
http://www.cisco.com/en/US/docs/security/asa/asa70/pix_upgrade/upgrade/guide/pixupgrd.htm">http://www.cisco.com/en/US/docs/security/asa/asa70/pix_upgrade/upgrade/guide/pixupgrd.htm
