CRS Node Manager keeps on Restarting the server
Jan 29th, 2009
I have 5.02 IPCCX installed on server and all of sudden server keeps on restarting saying, CISCO CRS Node Manager service terminated unexpectedly.
Any thoughts.
DAFitzgerald Tue, 02/10/2009 - 19:40
to my knowledge there is no work around for this issue, the fix is to format C: and do a reinstall. The problem seems to happen if you do the UCCX install and the UCCX server does not see the call manager or the call manager is not present during the install of UCCX or you have started the UCCX config and rebooted the server before finishing it. hope this may help
arrul-cco Tue, 02/10/2009 - 20:29
Once you installed OS, have you configured necessary IP address before install CRS. If you changed IP address after crs installation before running initial setup program, this may happen.
