Test AP Tx level when Wlan Surveying
Jan 29th, 2009
Can ayone confirm what is the industry standard Tx power level for a test AP and when simulating AP for a WLAN survey? I think I read somwhere its 25mW and not 50mW?
Scott Fella Thu, 01/29/2009 - 19:31
It depends on the device you will be using on the wlan. If you have wireless IP Phones that requires 25mW, then survey at 25mW. Some IP Phones might allwo you to go to 50mW. For data, you should stick to 50mW but again it depends on what devices you have. So on your autonomous AP:
100mW = 20dBi
50mW = 17dBi
25mW = 14dBi
mickh1777 Fri, 01/30/2009 - 01:56
Thanks for the feedback I have been told by the makers of the survey software we use they recommend surveying at 25mW and not 50mW for data or voice as areas surveyed at 50mW are at the top power setting.
Confused now but thanks for the feedback
Scott Fella Fri, 01/30/2009 - 05:03
25mW is a safe bet and usually is required for voice. 50mW is max TX on some if the 5ghz channels. So you set the power level that suits your requirements. If 802.11a is not required the 2.4ghz will max at 100mW. So figure out if 802.11a is required and go from there. Also try to use the same ap and antenna you plan on installing.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
