CCUM Seat Licenses
wrickk_2
From the License Unit Report and License Calculator I can view the number of seat licenses, but it doesn't display the number of seat licenses. Is there anywhere to view this information in CCUM?
Rob Huffman
Hi Rick,
As far as I know the Seat License is just a "paper" license and is not actually loaded anywhere on the box. It is not even shown in the License file;
Here is an example of the License File for CCM 5.x (but 6.x has a similar look and feel)
License File Contents
The license file contains the following information:
•Number of Cisco CallManager nodes that are licensed: This indicates number of Cisco CallManager servers in a cluster that are licensed to the customer.
•Versions of the Cisco CallManager that are supported.
•Number of phone units licensed: Instead of creating a separate license for each phone type, a concept of unit license is used. Each phone type corresponds to a fixed number of license units.
Here is an Example of Permanent CCM_Node licenses
# Optional usage agreement, legal language, tracking information
# Some other comments
INCREMENT CCM_NODE cisco 5.0 permanent uncounted \
VENDOR_STRING=3000BCD4EE59D1.0
ileVersion> \
HOSTID=000bcd4ee59d \
NOTICE="200508261405391621 \
" SIGN="19B3 4C6C 25AC 6D22 4D75 DE6A 656B 08C5 \
30E4 16DB 771B 1393 9DC1 DBC4 C5AA 15CC 6E6C B7B8 895A DCBA \
B40F C551 2625 1C97 F20D 9977 6CFF 3603 081E 6FF2"
The preceding license file includes the following information:
•No expiration date for this license exists as indicated by the keyword permanent.
•This license file provides three licenses for the version 5.0 of the feature CCM_NODES.
•The Cisco specific fieldLicFileID, identifies this license file.
•You can add multiple increment lines for same feature in a license file to increase the license count. None of the INCREMENT lines should be identical and each of them should be signed independently.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_0_1/ccmcfg/b02licfu.html
You would need to look at your PO# for Part numbers like these;
LIC-CM6.0-7845=License CM 6.0 7845 Appliance, 5,000 seat
LIC-CM6.X-2500= License Unified CM Additional 2500 Users
From this good doc;
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/product_data_sheet0900aecd805e323f.html
Hope this helps!
Rob
Rob Huffman
Hi Rick,
ileVersion> \
From this good doc;
Hope this helps!
Rob
Thanks Rob
