ACS 'Password Change Rule' doesn't work with telnet
Answered Question
Jan 29th, 2009
Hello:
I am trying to configure that users have to change their passwords when they enter to a network appliance the first time they log in.
I have an ACS 4.0 appliance, the option "Disable TELNET Change Password against this ACS and return the following message to the users telnet session" is disable. When I try to enter to a Catalyst 6500, for instance, I type user and pass and I get Rejected (RADIUS is the protocol used).
In the ACS' reports I can see it appears the next error 'Authen Failed - CS Password Expired'.
I only have enabled the option "Apply password change rule" in Group Settings, the others options for "Password Aging Rules" are deactivated.
Thanks for your help,
Francisco
Correct Answer by darpotter about 8 years 5 months ago
You'll need to be using TACACS+ to get password change to work.
Doesnt work with RADIUS.
Overall Rating: 5 (1 ratings)
Correct Answer
darpotter Thu, 01/29/2009 - 11:44
  • Silver, 250 points or more
