vss & supervisor 7203BXL
Jan 29th, 2009
Can i do VSS with a supervisor engine 7203BXL? wich card do I must add?
thanks
Giuseppe Larosa Thu, 01/29/2009 - 10:08
Hello Osvaldo,
VSS requires other supervisor models sup 720 3BXL is not supported
see
The virtual switching system requires Supervisor Engine 720 with 10-Gigabit Ethernet ports. You must use either two VS-S720-10G-3C or two VS-S720-10G-3CXL supervisor engine modules.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1053927
Hope to help
Giuseppe
languedoc Thu, 01/29/2009 - 14:12
hi
I thougth that if I had two 6500 with sup7203BXL cards , I could add a 8-port 10G card (WS-X6708-10G-3C/XL) with a DFC3CXL on each one for doing VSS. e.
Am I wrong?
Joseph W. Doherty Thu, 01/29/2009 - 16:48
My understanding is main supervisor needs either a VS-S720-10G-3C VS-S720-10G-3CXL, as Giuseppe already noted.
languedoc Fri, 01/30/2009 - 00:49
So I have to conclude that having a VSS structure cost a lot of money. Does it worth it?
Nice day to you all
Joseph W. Doherty Fri, 01/30/2009 - 04:22
Is it worth it, is the type of question that's really in the "eye of the beholder".
At to cost, yes it's expensive, but depending on you equipment provider, you might ask about trade in values for your sup720BXLs.
