How to save running-config to a text file
Jan 29th, 2009
I manage lot of router and switch my problem is before I do any changes to configuration file I want to save a copy of it
if I do sh run using putty it just displays one page worth of information and I have to do copy paste one page at a time
is there any easier method to copy paste entire running config to a text file ?
Overall Rating: 4.6 (10 ratings)
Giuseppe Larosa Thu, 01/29/2009 - 11:41
  • Hall of Fame,
    Founding Member
Hello Manish,
use
enable session> logging in putty using connection properties
then
term len 0
sh run
in this way all the file is placed without need to press for next page
then you stop logging and you have your file.
to have again pages type:
term len 25
putty saves an header with date and time at the beginning after that you have clean text file.
Hope to help
Giuseppe
Scott Peterson Tue, 04/08/2014 - 15:36
Thank you for the information, Giuseppe - it was precisely what I needed (5 years after you posted it :).
-Scott
Joseph W. Doherty Thu, 01/29/2009 - 12:21
Another option would be to send either the startup or running config to a TFTP, FTP or RCP server. The file will be text, although believe sequence of LFCR confuses Windows' Notepad but Wordpad renders it correctly.
drissbenattou Mon, 02/02/2009 - 02:42
You can tray to use this commande :
Router# terminal length 0
drissbenattou Mon, 02/02/2009 - 03:56
Mohamad Qayoom Fri, 02/13/2009 - 12:43
  • Bronze, 100 points or more
You can also use the following command from command prompt:
telnet -f fileName.txt x.x.x.x(IP)
Now everything that you do during this telnet session will be recorded in fileName.txt.
lscarbor Fri, 08/29/2014 - 11:10
  • Cisco Employee,
Hello MKCHAURASIA
If you are wondering how to copy your save running-config to a text file, my best suggestion would be to copy the outcome of the command line (via the CLI) and then open notepad and past the config there. Afterward, you can obviously save it to the desired folder!
Hope this helps!
Best regards,
Tish
jotran Mon, 02/23/2015 - 07:22
I am looking for an equivalent command to "show running | file $fn" in XML on IOS XR routers.
The command or steps I am looking for will help me save a running config in xml format to a file
on the router.
thanks
Joseph
