rommon commands to remove image
Jan 29th, 2009
I loaded an ios image on a sup2 and it was corrupt..I am sitting at the rommon prompt..how do I remove or what is the command I use to remove the image?
greatly appreciate the help...its a 6509..c6sup22-jk2o3sv-mz.121-27b.E4.bin is the image..
Edison Ortiz Thu, 01/29/2009 - 11:21
  • Hall of Fame,
    Founding Member
If it's corrupted, you will need a new image in order to boot into IOS. Most likely you will need to download a fresh image and xmodem the image to the 6500 file system.
This document covers this situation in details:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa1.shtml
HTH,
__
Edison.
Please rate helpful posts
ud0508500 Thu, 01/29/2009 - 11:37
thanks for the doc...but the image that is on the 6500 now is corrupt..It will not boot up..it errors out and goes to the rommon prompt..there is not enough space available in bootflash to load another image..do you know the command from rommon to delete the corrupt image? thank you for your help and time..appreciate it
Edison Ortiz Thu, 01/29/2009 - 11:49
  • Hall of Fame,
    Founding Member
When proceeding with the xmodem, you are given the option to erase the current image.
Please read the documentation.
__
Edison.
Leo Laohoo Thu, 01/29/2009 - 18:10
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
delete sup-bootdisk:c6sup22-jk2o3sv-mz.121-27b.E4.bin
Does this help?
